46" Firefloat What Motor/Battery
you might now be scratching your head, and wishing you have not asked the original question! This seems to be a common issue, as the boating community is light years behind the other disciplines, rc cars, planes helis and so on, its probably due to the facts general boating doesnt really need the later generation technology, the average boater age is probably higher than the other disciplines so budgeting might be an issue, and there is less younger blood in the clubs to explain the lipo/brushless etc.
We see posts with a load of numbers, specs, warnings etc, its enough to put people off.
Im a big fan of brushless/lipo/ 2.4 etc, been doing it for years, its cheaper and more efficient (once you have the basics) but for the average guy, who just wants to spend an easy afternoon at the local lake gently cruising around, brushed motors, nimhs batteries, even lead acid, will do the job👍
Your 4 foot ply boat, once painted, with fittings, will be heavy, I know, I own one. Those 600 motors are not big enough, they are better suited to the smaller 3 foot boat, then, pushing them with a 6v lead acid, just cant do it. The battery will be screaming HELP!! I started 15 years back exactly the same, 600 motor, 6v battery, massive 50mm prop, I knew no better and took advise from people who didnt know what they were talking about😡, remember those gold hi tech speed controllers!! I had one, it melted, literally melted on the first use😭
Get 700 size motors, they will need to be water cooled, as mentioned by jarvo, the nominal voltage or below isnt good enough, power them at the max voltage. Brushed means you can use one apropriate esc, look out for electronize (are they still in existance?) or mtroniks, preferably use nimhs batteries over lead acid with a high mah.
If after all this you want to venture into lipos and brushless motors, go to a club, spot a boat that is similar in size to yours, if you like the performance talk to the owner and gain experience and knowledge that way, it will save money, lost time and a lot of disappointment, I have been there so feel your pain.
I say I would never go back to brushed motors and none lipo batteries, but I always want silly speed, not runtime, after 15 minutes Ive had enough and am bored. Rambling over!
My 4 foot boat is twin brushless and uses 4 lipo 5000mah cells per motor, it will do 25mph for 15 mins, then I go home😁
Message is, you can get a "reasonable" performance from brushed motors, with the correct batteries, right props, but weight is the enemy. Looks lie you are at Biddulph, get onto Dave M a moderator on here, and arrange to go over to see the crewe and district boys on one of their sailing days, take your boat with you, they will help👍
