Seabreacher
Hi Steve
The Graupner Speed 900BB Torque specs are 6-40 volts, 6,500 rpm, 54A amps, shaft 6mm, dia. 51.5 mm, length 95mm and weight 645 grams.
A brushless motor like the Hobbyking L5055 600kv is 11.1- 22.5 volts(3S -6S) power 1500watts, 55 Amps, shaft 6mm, dia. 50mm, length 55mm and weight 311 grams.
On 3S=6660 rpm, 4S=8880 rpm and 6S=13500 rpm.
The brushless motors are far more powerful and with an ESC with handles up to 6S(22.5 volts) you would have rpm's to drive
a water jet unit.
Canabus
