Sea commander
Started by cockachumpy
9 replies 14 likes Last activity: 4 years ago
#8 1
Sea commander
Guys, thank you for your support, It great to know other people are so kind. keep sailing. XX
Liked by Colin H
#7 1
Sea commander
HI Exsnapper
Mine has a 1100kv motor, but is no longer available.
So recommend a Banggood Surpass Hobby C3542-1250kv with a brushless 60/80 Amp ESC. Both required to handle 2 to 4S Lipo batteries( 3000mah 60C) and a 2 blade 40mm prop. No water cooling required for the motor and if you use a car ESC general they have an electric fan for cooling.
Install to motor just forward of frame 4 and mount the battery cross ways in front of that.
Canabus
Liked by cockachumpy and Colin H and
Sea commander
cockachumpy,
I have found the set of plans 🤓, if you want me to post to you PM me with your address.
Phil
Liked by Colin H
Sea commander
Canabus, I have a new one to build, and hope that I can match your quality of workmanship. I'm also interested in your brushless combo as my previous Commander had the originally supplied 750 can motor and a 12v SLA battery. Im probably not going to build until early next year.
Liked by Colin H
Sea commander
PDF Copy of the Sea Commander.
Coffee stir sticks for deck planking and cabin floor.
35mm 1100Kv brushless motor on 3S Lipo battery and 40mm 2 blade prop. ESC 60 Amp.👍
Canabus
Liked by rocketpilot and cockachumpy and
Sea commander
I think I have a set of plans for the aerokits sea commander 35” version somewhere up in my loft. I can check out tomorrow
Sea commander
Hi, I wonder if anybody can help. Im after a set of planes for the sea commander. Need to carry out some refurbishment work.
Liked by NickD
