Aero Kit Sea Commander
I agree with Colin.
A good solid building board is also essential. 3/4" MDF is my preferred choice. Mark a centre line down the length of the board. Depending on how you are building the hull make sure your keel follows the line or frames are equally spaced about thew line. I would tack glue blocks of wood to the keel or frames to keep everything straight and square.
A dry run will show up any problems which you must resolve before starting to glue. I usually use cyano to tack in place initially.
Take your time and check, check and check again.
Before you skin the hull you may want to fit the propshaft and motor as alignment will be so much easier.
Good luck with the build 😀
