Brass Pins
Followers (3)
Brass Pins
Drilling the pilot holes will stop the pins bending Seaspray.
Essential when 'bashing' soft brass pins into hard wood 😉
So now you've got enough pins to build 10 ships 😀
More power to your pin drill 👍
Brass Pins
While putting the new pins away I found these ones. The oldest packet is at the bottom from a Nor Star Wave Princess kit bought in 1971. They kept bending so I never used them
Brass Pins
Pin pushers The one I have I think it is too big for a 7 mm pin
https://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?WD=pin%20ousher&PN=mantua_nail_fixer%2Ehtml#SID=446
Brass Pins
At the risk of teaching Granny to process raw eggs 😁
Drill pilot holes to avoid splitting the stringers or planks!
Mind your fingers with the tack hammer, I hold the pins with a small pair of fine point pliers to get 'em started.
Alternative; a Pin Pusher, Amati or similar 👍 There are loads on the Web.
Brass Pins
Good choice Seaspray🤞
Seems there's No Point in buying the 12mm pins 🙄
https://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?WD=brass%20pins%20building&PN=4135%2D12%2DBrass%2DPins%2D12mm%2DNo%2DPoint%2D%2D100%2D%2DA4135_12%2Ehtml#SID=378
Brass Pins
Brass Pins
https://www.cornwallmodelboats.co.uk/cgi-bin/ss000001.pl?page=search&SS=brass+building+pins+&PR=-1&TB=O&ACTION=Go%21
Brass Pins
There are some for sale on EBay although I don't know if they are the length you require.
Will
Precedent Fairey Huntsman 46"
Veron Fairey Huntsman 28 42"
Precedent Fairey Huntsman 36"
Aerokits Sea Commander 34"
Aerokits Sea Rover 29 1/2"
SLEC Fairey Huntress 23"
Brass Pins
Brass Pins
Liked by
Loading…
