A simple way to make a sail. Cut out a pattern of the sail in card. Lay on the fabric to be used with the port side facing upwards and the selvedge of the fabric on the leach of the sail Draw around the other sides of the card pattern onto the fabric. Now draw another line around the card pattern on the fabric the width of the self adhesive tape you are using outside the card pattern. Cut out on this line. Put the self adhesive tape all around the pattern on the inside of the innermost line on the fabric. Ignore the selvedge. Turn the fabric over onto the self adhesive tape, mitreing the corners. so that you have a sail strengthened all round with another layer of fabric. If this sail is for a modern racing yacht or similar, just insert eyelets in the corners or where needed. If it is for a traditional boat, barge, pilot cutter etc. The sail will need roping. Sails are traditionally roped on the port side of the sail which is why I said to lay the card pattern on the fabric port side up. I use about a 5mm cord and sew it around the outside edge of the sail except the leach to strengthen it and give it a traditional look. You can incorporate any eyes ((loops) at the corners you may want into it.
The experts will give you instructions for making sails far more complicated than this, but this is a method I have used perfectly successfully over the years.
Cheers, Nerys
Cheers, Nerys
Hi Rus,
I am glad you received the help you required from the members.
Looking forward to further progress reports.
Wow thank you guys!!!!
Wonderful information and I just joined. Thank you for all your input.
I will carry on and share my progress.
Through my research, I have found there is a rich history of pond boats on the UK. As I proceed, I would enjoy very much tackling a pond boat from the early times in the UK.
Rus
Rus
"double sided tape for fabric"
Like iron on bias binding Nerys - any half decent haberdasher will have it.
For instance-
https://plushaddict.co.uk/haberdashery/bias-binding.html?cat=1014
https://plushaddict.co.uk/haberdashery/bias-binding/vlieseline-vilene-bias-tape-white.html
Good for fixing trouser hems as well 😁
Hi Nerys,
Would it be possible for you to do a little article with photos on your sail making process as it could help the newer guys to this hobby.
Hi Nerys,
As I am about to make sails for my latest model barge, I thought I might stick this set instead of sewing by hand as I usually do. Looked on Ebay for double sided tape for fabric and there were several offers, even mentioning sails. Several widths from 6mm and lengths from 6m to 50m. Worth a look. I am about to decide which I will order.
Cheers, Nerys
Cheers, Nerys
Hi I have cut out sails using a sharpened soldering iron bit at a minimum heat level You do need a firm durface to cut the sail on but I made the mistake of using hardboard and there is a faint brown mark which is not a burn mark from the hardboard surface.
The last lot of sails I 'made' I produced templates supplied the material and left an example of what was wanted and the lady who does clothing alterations in the local market did the sewing. Did not charge much either.
Remember to have the longest sail edge as the weft edge i.e. non stretching.
regards
Hi if the sail material is a flat surface like mylar film double sided tape is great. If it is a woven surface then there is a product called Wunda Web which is a loose filament tape which is glue and it can be laid inside a seam.
This is then ironed with the heat on medium to activate the glue to the two surfaces. Not sure if this would suit nylon or rip stock but would be good for a light cotton material.
I have sails made in this way over 10 years ago with no sign of deterioration.
If you have a material which when cut has threads ready to fall away then using a cotton bud stick apply a light varnish edge on to the cut adge and this will seal it form fraying.
Good luck
Hi 5280PB,
Welcome to the site.
Have you had a look on youtube. ?
I do recall mention of using double sided tap instead of sowing the seems.
Maybe one of our sailboat members will be able to give you more information.
Hi 5280PB,
Hi all,
I am interested in how to make sails for my Petit Bateau. These are sailed in the gardens in Paris. I am looking to make simply sails of nylon, dacron or ripstop? I would like to stay away from sewing. I thought I saw that you can hold the seams with two sided tape.
Any help would be greatly appreciated!
Thank you,
Rus
[{"id":"161840625162","name":"161840625162","caption":"","url":"https:\/\/beta.model-boats.com\/media\/161840625162\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/161840625162\/s","isImage":false,"ext":"file"}]
Hi all,
Thank you,
Rus
