Laser cutter engraver
Started by jbkiwi
6 replies 17 likes Last activity: 3 years ago
In answer to Red there are speciaist suppliers of laser cutting materials which sell specially formulated no toxic mdf and ply that use non formaldehyde binders. Mine will happily cut 3mm ply and mdf in one pass and I have engraved slate, stone stainless steel and a whole range of hardwoods...
Liked by Mike Stoney and Len1 and
I have an Ortur Laser Master 2 Pro. A decent machine capable of proper work. It is easy to assemble and set up and runs on Lasergrbl or Lightburn (and probably others. It has a decent 400 x 400mm workspace but can be expanded..With any laser you will also need a small compressor for air assist and some form of extraction...
Michel C
There are people who are always lucky… informing about laser cutters when you ordered one.
Is this the world upside down😂😂
Hello everyone,
Who owns such a laser cutter, which types are good for small parts? Who can give me a tip before I risk something again?
Had ordered one and now, oh luck, the money back received, company is bankrupt (like our bank CS 🙈🙉🙊 Big sh..! )
Thanks for your help
Hobbyist greetings
Agree 1000% Red 👍
Liked by dave976
I would be very careful with this sort of laser - there is not only the danger of being blinded - but there is other harmful radiation emitted too. Plus these small lasers are very weak and would probably battle to cut through 2mm hard Balsa ! There are other dangers too - such as ABS giving off cyanide gas when laser cut , MDF emits a poisonous gas caused by the formaldehyde it is glued with , and vinyl plastics such as old records give off a highly corrosive gas - deadly for your lungs. Even the gas emitted by polystyrene & perspex does not do you much good .
The only small laser I would go for is a fully enclosed table top model of a least 40w power and fitted with a filter or extractor system . Anything under 20w is only good for cutting paper or card - and the smoke from that is not good for the lungs either.............. plus 20 or 30w lasers battle to cut anything.
Check this cool item out from Banggood, have to have a use in modelling?!
Liked by Mike Stoney and JOHN and
