Clinker ships boats.
Followers (3)
A tricky little boat to build but you have done a great job.
Well done.
Spot of sanding before the white top coat perhaps?
Primer & first gloss coat, one more then Matt varnish. Must not be to shiny. Thwarts will be yacht varnish shiny mahogany. Not fixed in photo.
The block of iron is removable ballast used in my pilot cutter.
So do I Hammer 🤞
For the next one try holding the pattern in place with a layer of cling film 👍
"Then paint. I don’t think wood is best at this size, plastic card would be a lot easier to work with. "
But it wouldn't look half as good Hammer 🤔 Hat off Sir ☀️
Please don't paint it (unless the ship it is destined for demands it).
It looks so good in natural wood 👍
Cheers, Doug
For scale ribs should be spaced at 1/4” but will look better @ 3/8. That’s my excuse.
The transom is only thin at the top. It was fitted on a slight angle outwards, so at the bottom almost the whole of the balsa is still there.
No not sunk. 😂
Sticking thin bamboo inside top edge.
The transom cut down to scale thickness. Used 1.5mm ply with 5mm balsa stuck to back. This takes the pins & removed after construction.
"It’s out dying in the warm sunshine"
Sorry to hear that the boat is sick 🤔 not Covid related I hope?
OK OK I was just leaving ... 😔
Preparing to fit out the inside, strip bamboo kebab sticks.
Some of you may have noticed a difference in the boat from before I stopped. Truth is I started again as i couldn’t find the original. I had put it somewhere safe. Found it today in my metal shop. It is the same size as the new. Just the photo. Notice how it has kept its shape with the former removed.
Look after yourself.
Stephen.
Only the chamfer at the stem is handed. It is surprising how wide a plank needs be to accommodate the shape at the bilge. That is why full-size have planks about 2” showing.
I never throw anything away. I saved some ply that someone had left outside. Totally come apart. I am now sticking mahogany veneer on one side to make 2mm 2 ply. Be using this for thwarts etc.
I am enjoying your write ups.
I note that you say you are “Not too well”.
Take care and stay safe.
Regards Bill.
The reason I am making a new boat. I made one (in photo) to long. So i cut an inch of the back. It fits on the hatch but spoiled the shape.
Keel joined & setup on jig.
First job cut out keel with stem, transom & centre former. At this size 3 pieces to form the keel - stem. Glued together to form a rebate on each side. On larger sizes I cut grooves.
Transom & centre former drawn freehand on folded paper, cut out unfold. The extensions are to fit on a jig. Glued to ply with contact adhesive. (Eco Stick) this stops the paper distorting.
Not being a mathematician a simple drawing gives the spacing for the 3 positions. Strips of paper marked from this and stuck to edges. On larger models 2 or even 3 temporary formers used.
Liked by
Loading…
