wooden hull strengthening
Instant is the worst for me several times I have had to cut myself free with a knife. Also clear (bathroom) sealant.
I advocate this for sticking down electric motors, it holds them firmly absorbs some unwanted vibration and with a bit of easing you can release the motor unmarked.
Good luck with the build
If water gets into wood over a period of time it will swell up and it does nor matter what your finish is it will expose cracks and weak points in the hull.
Another thought is to balance the inner and outer surfaces so that neither one can expand or contract more than the other, varnish or the like inside will give the wood stability.
Nerys points out his method of building which is a purpose composite system and a good combination for a lightweight hull. No point in adding extra strengthening where none is needed.
I have seen Robob's hulls and they are an immaculate surface finish but which ever way you go it takes time and effort. But the finish will last and the model will live on!
Rick
Nerys
Not a sign of glass fibre on any of them. If you build in wood then a few coats of thinned varnish will toughen the surface, then just get rid of your old paints as you brush the paint on and wet and dry in between. With different colour paint layers you can see how deep you go when using wet and dry to get a good surface.
Most of my models have 10 plus coats of paint, well keyed in and have lasted well. I usually finish with an abrasive rub down of Vim (seems to have vanished from the shops) and then a couple of coats of good quality polish.
If you need strength in a hull start with thicker planking, just how strong does a hull need to be? I agree you can obtain a pristine finish but few full size boats are like that.
I also note that some go off into the realms of marquetary with deck planking. Most full size decks used teak for some very good reasons.
Over the years I may have refurbished a boat but one of my oldest has balsa planking and has survived very well.
By the way inside I sometimes use old stocking panels and varnish, just as good, also a good substitute for canvas. Many working boats from the 50s and 60s had canvass decks as well.
In the past when money was tight I used some of the wife's tights.
Just push you boat down the leg and pull until the leg is tight and tie off the open end, then brush on the resin, I don't know if today's tight will work.
Fred
On my Pilot Boat I used glassfibre twill cloth and epoxy resin.
Don't try to cover the hull in one piece as you will have big problems avoiding creases and it would be really unmanageable. I did mine in five stages
the last being the transom. Have a look at my Pilot Boat build blog to see how I did mine.
Rob.
I have used GF before on other projects but always seemed to get bubbles creases etc.
Thanks for any input
Liked by
Loading…
