Lipo Alarms
Yeah, I'd also noticed that the HK site has been a little erratic and very slow lately🤔
And Yeah again! I know those alarm gizmos.
As they are cheap as chips I bought a handful of 'em a while back.
I mostly use them for quick checks of LiPo charge state.
BUT! You can ONLY use 'em for LiPos. So doesn't fit your bill🤔
They are not programmed for any other type.
So if you manage to plug in a NiMh or SLA (the gadget is only designed to accept LiPo balance plugs) it'll probably assume it's the nearest LiPo voltage and give you a false reading, may even bleep at you even if the battery is fully charged.
That's why I recommended the other one for your purpose (and why I bought one!) You loop your ESC / Motor supply wires through it at one end, any battery type, and it measures voltage and current ON LOAD. If you use a LiPo you can plug the balance cable in the other end and it will measure the cell voltages as well😊
