Marking waterline
Marking waterline
Marking waterline
Hopefully the Fleet Admiral won't keel haul me as a result 😰
The measurements (for the 34" Fire Boat) were worked out from the original plans and are all measured from the deck with the Stern being 6.4cm and the Bow being 9cm.
Then all that is needed (as Dave points out) is to make a suitable pencil holder and arrange the markings to achieve the level needed to scribe the line evenly all the way round.
You will notice from the photo that I used a load of books to achieve the appropriate level and an area where I could work all the way around without any interference (kitchen table)
Once the line was on I then found that the boat was slightly twisted/not level and so a few adjustments were made to ensure equal spacing.
Good luck 👍
Marking waterline
I am assuming you have already fully cleaned and prepped the hull before you started the restoration. As it has been stored for many years any splits in the wood or glue joints will also need to be fixed.
To achieve a level line you should place the boat in a cradle (use a spirit level) on a flat table, then attach a soft pencil with rubber bands to a piece of wood, Adjust the height of the pencil to where you require the waterline and mark all round the hull, being careful to keep the wood and pencil perpendicular.
Your chosen masking tape can then be applied to the marked line, making sure there are no gaps.
Paint the base and put some paint on the masking tape. Check from time to time and when a test on the masking tape paint indicates the paint is finger safe, carefully remove the masking tape, ensuring you do not touch the new paint until it is completely hardened.
If you leave the tape on until the paint hardens you run the risk of leaving a ridge between the new and old paints.
Good luck 😀
Marking waterline
Marking waterline
I have been repainting It but marking the waterline Is looking a bit tricky to me. Does any one have a method for applying the masking tape so that I can paint the bottom red. Thanks In advance
Liked by
Loading…
