Lipo battery charger
You were reading my thoughts JB👍
There are lots of copies of this charger and it's hard to tell if they are the genuine Sky RC versions without having a known genuine one to compare internals. The copies work ok but aren't as accurate or reliable as the genuine ones. Early versions with the internal power supply had issues with the power supply overheating so just keep your eye on it. Can you try it on PB, NiMH, Li-ion etc and see if it works on those batteries?
The charger has a battery test facility.
This shows a) total voltage 3.7V rather than the 11.1 to be expected.
This seems to explain the "no battery" message,because the charger is looking for the 11.1v to be expected from 3S.
However when the battery is metered,it shows 11.1V. This
suggests to me that the charger is not detecting two of the cells.I can only now get a new charger and hope I am correct!
Thanks for all replies.
All settings correct.
Tried different charge modes.
Metered battery right up to banana plugs,also across each cell on balance lead. ????????! If I do not connect balance lead,it says
"connection error".Connect balance lead " no battery".Just don't
Know.charger is powered on AC lead,230V.
It's pretty hard to damage these chargers as they have a number of safety features to tell if you have done something wrong, also they are probably one of the most common chargers around and are generally pretty reliable and this sounds a bit unusual. Also is there enough input voltage to power the charger (at least around 12v 5A normally)
Ihave a Imax B6 V2 lipo charger.It has been used about four times over two years or so to maintain charge on a Turnigy 4S battery.
The last time I used it,it indicated a faulty battery;upon inspection,one cell was completely "puffed".
I now have an Overlander 3S battery that today I tried to charge (It is new and unused).The charger says " no battery".when starting to charge.
I have metered the main battery leads,and get 11.3V.
I have metered across each balance terminal and get 3.7V on each
cell.So,battery looks OK. How likely is it that the charger is faulty
or was damaged by the faulty Turnigy battery.I am in unknown territory here,so would really appreciate any advice.
Liked by
Loading…
