Schottel drives or Kort Nozzle
Started by highwayman
4 replies 6 likes Last activity: 6 years ago
Look for Thrusters on this website. ( Had to think there!)
Liked by Martin555
Just a bit more info
Schottel's are used on the craft that needs high maneuverability and hold points. A schottel rotates 360 Degrees. Sometimes these are encased in a Kort Nozzle which assists thrust, With the full-size version of what you are building these would have been fitted as the craft has to hold position against an oil rig. Water Tractors (Modern day tugs) use them and they can almost turn on its own centre.
A steerable Kort nozzle will only move about 60 Degrees when being driven by a propeller.
So I suggest you chat with someone in your boat club about it as it depends on what you want to do.
Schottel's are robust but expensive.
Good Luck
Liked by Martin555
A schottel is only a steerable kort in most cases.
Not much goes wrong with them.
There is a discussion on the forum about schottel and Voith Schneider drives.
You can also get Steerable Korts from Mobile Marine Models
Liked by Colin H and Martin555
I am seriously considering making the Shell Pioneer by Phil Thomas. Apart from cost as the schottle seems very expensive and I would think prone to break downs considering the spare parts advertised. What are your thoughts on pros and cons?
Liked by Martin555
