size brass sheet.
Started by octman
3 replies 4 likes Last activity: 7 years ago
size brass sheet.
Thanks chaps,
Both sites now bookmarked.
Liked by Martin555
size brass sheet.
I am trying to obtain some 1mm x 2mm x 1 metre(or however long it has to be) brass sheet. Does it exist, as all the sizes I have found so far are too big? If I have buy a sheet either 1 or 2 mm thick but a bit wider and then cut the required width I assume I will have to use something like a guillotine. Any suggestions on a suitable piece of equipment to do this, or even better, a source of brass sheet that is the correct size in the first place.
