Trawler build
Trawler build
Richard
Trawler build
Carry on Petty Officer👍
Steady as you go😉
Trawler build
Regards Sid
Trawler build
Eze Kote – deluxematerials.com
I have also attached a photo of the bottle.
"Over to you Admiral"
Cheers Richard
Trawler build
I had the same problem with my Danish Fish Cutter Gina 2 from Billing.
See blog here-
https://model-boats.com/blogs/43305
I sealed the balsa stern block with Deluxe Materials Eze-Kote which is a water based resin.
Two coats diluted with about 20% water so it soaked into the balsa, then two or three coats pure to add strength and scratch and knock resistance.
There are two Deluxe Materials importer / distributors in OZ,
https://deluxematerials.co.uk/collections/distributors#australia
one should be able to tell where you can get some🤞
Trawler build
I am building a Billing Boats Tug ‘St Canute’ during this build l had major problems applying the planking to the stern. So l turned to my Pals on this website who advised blocks of balsa in place of the planks, carved and shaped. I have attached a picture of the stern and the balsa sealer l used. I found this sealer very good, it’s non toxic and you can use water to clean brushes. So far l have three Coates and it seems to harden the balsa and seal nicely. I then intend to apply primer and spray paint later. I am sure you will hear from the other very experienced chaps on this website with alternatives.
All the best from a wet and windy UK
Richard
Liked by
Loading…
