Battery sizing
Followers (5)
- BOATSHEDBronze
- RookysailorSilver
- mturpin013Bronze
Battery sizing
The lake is at Clarence Park Lido, BURY, LANCS.
Battery sizing
Battery sizing
Battery sizing
Battery sizing
3s 5000mah Turnigy lipo, I find this fast enough and gets on the plane within 10ft, have used a 2s lipo,
if the lake is busy, but still goes like S***.😐
Cheers, Pete
Battery sizing
Specs:
RPM/v: 2200kv
Poles: 4
Max voltage: 18.5V (5S)
Max Current: 100A
Max Watts: 1200w
Resistance: 0.0094ohm
No Load Current: 2.9A
Can Diameter: 39mm (actual motor diameter)
Can Diameter inc. Water Jacket: 49mm
Can Length: 69mm
Shaft Size: 5mm
Weight: 415g
Battery sizing
Have been absent for a while ,having been sidelined with plastic kits; but having made them,what to DO with them!
I have built a very respectable 50" KD Perkasa.
Have never had it in the water,but recently found a club water within reasonable travelling distance and want to USE it.
I have been regularly maintenance smart charging the Li Po battery until it burst (Turnigy).
The motor is a Turnigy Aquastar 3974 2200 Kv brushless with Turnigy water cooled ESC. Prop is a single 50mm.
Please can someone advise me on what size battery I need.
Liked by
Loading…
