Shroud
Started by retirement-hobby
12 replies 5 likes Last activity: 8 years ago
Shroud
Thanks, now I'm restoring the boat it came from. Going to try plastic next.
TS
Shroud
Yes - drilling small holes on circular surfaces is difficult.
Do you have a small dremel-type drill with some disc cutters? If so, a light cut across the top of the tube would be easy to do accurately and would leave a small hole. If the cut was too deep it might weaken the brass tube, but for a static model that would be fine. The solder would flow into the cut and hide it completely. You could even do it with a triangular needle file.
If the cut did not go completely through it would still help in centring the drill. The nice thing about drilling holes is that you then have 1/8" excess tolerance that you can cut the vertical wires to - they will slide up and down in the tube...
You can also cut tubes precisely to shape, then join them temporarily with a bit of mains copper wire inside, making very neat joints. See pictures 5, 6 and 7 on this page -
Shroud
Thanks, no experience with that. Will give it some thought. Im using 1/8 rod, without a drill press that would be hard to do.
TS
Shroud
That soldering looks as if it will be stronger than wire.
If you want a neater finish, you could drill holes in the large tubes to accept the smaller rods. This would be easier to solder, neater and more precise.
Liked by retirement-hobby
Shroud
A shroud is the metal framework around the airboat engine to protect the propeller. When I built theboats I have, I used wire and super glue. It didnt stand the test of time.
TS
Liked by Inkoust
Shroud
perhaps a picture showing what you are trying to do would enable us to give more directed advice...
Liked by vc killer
Shroud
The soldered one didnt come out quite like I expected, so Im trying with balsa sticks. Again, template, alignment, what type glue, etc. Also going to try with propane torch, concerns with bending still being researched.
TS
