Vic Smeed's 'Waterbaby'
How does one become an 'expert'?
LEARNING BY DOING!!! 😉
As they say in this neck o the woods 'Übung macht den Meister' - 'Practice makes the master'!
I think its time to drill the lead keel as suggested. I have found a local expert who says he will do the job! Will report on progress.
Many thanks.
John
I will put some more pictures up hopefully tomorrow.
Can you identify which parts of the keel are lead? if you can then you could just drill holes into it (as close to rear as possible) to reduce its weight. Keep drilling and doing buoyancy tests until you are happy then leave it to dry out before filling the holes with car body filler.
One issue of interest is the keel weight which seems a little too heavy so the boat lies a little too low in the water. Has anyone made modifications to the keel? What is the best way to do this and how do you maintain good fore and aft trim?
Liked by
Loading…
