Southampton Tug Boat
Started by Weedman
2 replies 2 likes Last activity: 5 months ago
Remove all deck fittings, vents, hydrants, bollards and bits, as screws are concealed under these, carefully save all screws and remember to replace and tighten them in a uniform order ! The boat deck and hull are sealed together with a rubber seal and grease gently go around the join with a flat tool like a putty knife and gently ease the two apart equally. Watch out for grease, can be messy !😠
Alan
I assume you have moved on from the above.
How did it go?
Cheers.
NPJ
NPJ
Liked by doghouse
Can anyone help especially with step by step instructions. Better still, by sending me a video something similar to that which has been seen on YouTube. There is one about upgrading but that showed the deck already removed.
I need help with dismantling the Hobby Engine Southampton Tug Boat which I purchased today. I want first to remove the deck without damaging any part, naturally. I know the removal of screws is necessary all around the deck but for some reason this dose not release the deck unless, it is secured with glue or am I missing something?
Then, I can remove all RC equipment replacing it with my own. Lastly, I want to upgrade the battery from the standard 6 cell AA 800mAh 7.2v to a 1800mAh 7.4v or even a 3000mAh Lipo which will probably have to be relocated.
All help, advice or suggestions would be appreciated. Keep it clean. Thank you.
Liked by Ballast
