rear deck
rear deck
the way I do the decks as I do on all boats is to use some 1/64 ply and plank non top that way I can do it on the bench and if it needs a camber I do it over a cambered former, you can plank in half the time and sand with a big block, all of the first plasticard version was scraped and a new one made as you can see the two together, it just lifts out in seconds after the tow hook is removed.the pictures show a part painted rear deck youn can see where the brass pieces join to the fixed part.
Peter
rear deck
Many thanks for posting all that detail - an Impressive boat I must say. I too have edged the well deck sides with K&S Brass channel, it looks so good. is that a laminate type floor that you have fitted to this deck?
I did wonder about fitting lockers/benches here too but I anticipated having trouble removing the deck to get to the rudder?
Is that a home made brass transom/support fitted below the towing hook?
Did you control the bilge pump from the RC?
PeteG
rear deck
Anyway here are some pictures, of the two decks, there Is very little difference In weight between them. Also a picture of some of the fittings I have made for It.
Peter
Liked by
Loading…
