Li-Ion Batteries
Li-Ion Batteries
I use these batteries and apart from the cheap Chinese imports they can give a high current. The drawback is that they are protected internally against overheating and as a result they can (and do) sometimes just stop working until they cool down.
In a heavy current setting such as a tug for tug football or a fast electric this is what happens. if you are using in a more sedate model with low current draw they are fine. Also excellent for rx batteries with a switch mode psu.
They are Lithium technology so do need to be balanced charged with the correct charger, but are more resilient than LiPos but still need to be respected.
Common usage is in a rechargeable electric drill etc.
You can buy battery holders for the cells which will avoid having to solder and makes charging easier
I remember Torchy, just
Li-Ion Batteries
Liked by
Loading…
