what motor
Started by marky
5 replies 2 likes 0 followers Last activity: 9 years ago
what motor
Bon chance mon ami! 👍
I can send you the RC set manual if you like, just pm-ed you my Email address. We can't attach pdf files to posts (pm or not) 🤔
Cheers and Goodnight from Munich, 😎Doug
what motor
Thanks Doug ,much appreciated looks like Hobbyking shopping for me tommorow .
Cheers Marky
what motor
OK. So it's 4" smaller than the Sea Scout I am currently renovating and upgrading from a 50ies Taycol motor to brushless! So keep the 'stuf' lightweight.
When I asked the same question for the Sea Scout a few months ago I got the following advice from Canabus, who seems to have considerable experience in this field 👍
"All from Hobbyking.
Motor propdrive V2 2830- 1000kv 370watts 3.175mm shaft(9190000328-0)3S or 4S lipo battery.
ESC 30A car(HK-30A)( XT60 connectors required), program card (HKPROG-CARD)can be used on the larger ones in the series.
Lipo battery Turnigy 1000mah 3S 30C (T1000.3s.20) 89grams 75 x 33 x 19mm or a Turnigy 1500mah 3S 25C (T1500.3S.25) 113 grams 80 x 34 x 25 mm both have XT60 connectors.
Prop about a 2 blade 30mm 1.4 pitch"
I actually opted for a 3 blade prop and a 3S 3000mAh I already had, but bought the ESC and motor recommended and am now fitting them cos it made sense, was not expensive and came pretty quick - make sure it comes from the UK or EU warehouse to avoid possible import tax from Hong Kong or USA !!!
This would be more than adequate to give your boat some Oomph! it needs more than my cabin Cruiser!
For the RC buy a complete set already matched and 'bound' so you have the minimum of fiddling about as a rookie😉
I can thoroughly recommend the Turnigy HT6, AKA TGY-I6 , ~US$45 also from Hobby King. in a couple of hours one evening I could programme two models into it and get it to do what I wanted instead of what the factory thought we would want for plane or chopper!
Instructions are quite clear, logical and lead you through step by step. it comes with a 68 page manual! But much you can skip if you don't intend to go flying with your boat!
Attached is a pic from my manual with German branding (REELY)! But it's the same beast as the TGY-I6, second pic!!
The whole package should cost around a 100quid and you're RTR!
The RC set has 6 channels so you have lots of scope later for special functions; fire monitors, lights, horn, motor noise etc etc 👍
By the way; the motor comes with 3.5mm bullet connectors, and of course I only had 4mm 'other halves' but you can also get connectors, loose or fitted to cables and adapters at Hobby King.
(You can solder them on with your 4lb hatchet!!!)
Hope this helps,
Cheers Doug 😎
PS don't forget a suitable coupling to match the 3.17mm motor shaft to your prop shaft (whatever that is, 4mm?)
Liked by AllenA and marky
what motor
Hi Doug,its 20" (500mm) long x 5"(125mm)at its widest.Cheers Marky 😌
what motor
Hi Mark, remind me please; how big is the boat ?
Doug 😎
what motor
Am building the EEZEBILT RAF tender the hints and tips suggest a 280 or 300 brushed motor but on other posts in the forums brushless motors are mentioned ,both my previous boats have been static so this is a steep learning curve for me ,Q1 brushed or brushless ?.Q2 what size ? Q3 would it be easier to buy a RC set up complete rather than individual bits and bobs ?.Q4 will defiantly follow in the near future .
Any help much appreciated 👍 Cheers Marky
