Hi Fred, I take it you have the 91W version (#6316) see pic for specs.
It has a 42mm dia. case and a 5mm shaft.
So I would try 2x 35 to 40mm max. props.
Shafts: 5mm, if you can, find one with needle roller bearings, try Raboesch (the most expensive of course! But very good and robust.) if you are going for 'all out speed'! Zoom zoom 😉
http://raboeschmodels.com/index.php/en/
If not ball bearings, last resort sintered phosphor bronze bushes.
Fit an oiler if the tube doesn't come with one.
Will you use a 7.2, 9.6 or 12V battery (or a LiPo somewhere in between!)?
Good luck and happy sailing, Doug 😎
