Paint removal
If the deck is also GRP the best bet is to plank it with fine veneer strips then varnish that. if it needs filler between the planks use a black one. Carbon black or similar added to the filler .Brown would also look smart.Artists powder paint could also be used and be cleaner to handle.Lite filler from B&Q is very good .Light and easy sanding and I believe slightly flexible so should not crack out.
