Soldering 1/12 Scale Brass Railings
It's alright Marky ! Mine has a new rubber flex and has been overhauled by an electrician, thanks for your concern!!! I found I was really comfortable with it and my confidence grew with every solder !
cheers Marky
Look like good soldered joints. You should be proud of your achievement.
Tin/lead solder is still out there and I agree with Dave not being a fan of lead free solders
I make many of my fittings out of brass and provided you keep everything clean and free from oil especially from your hands the process is as Haverlock has described.
I use a small pot of FR Power Flux bought from the local pound shop, it's for lead free solder but works fine with my lead cored solder. I am not a fan of the new lead free solder and find it difficult to use, so if you can try and source some cored solder that doesn't conform to the new lead free standard.
At 2mm you will not need a high wattage (possibly 15-20 watts), I have a temp controlled iron so can adjust the heat.
A jig to hold everything square is essential and if you are soldering near to a previous joint you may need a wet cloth or a lump of metal to act as a heat sink to protect the previous joint.
Please keep us posted with your progress, many others struggle with soldering so your efforts will perhaps help them to take the plunge.
Good lick
Liked by
Loading…
