Best sanding sealer?
Started by justintime2001
4 replies 2 likes 0 followers Last activity: 10 years ago
I make my own sanding sealer with clear dope and talc or micro ballons.I thin the dope up to 50% and vary the fillers according to the grain etc i wish to seal.You can ajust the proportions to suit yourself. The greater the fillers to dope the easier to sand . I usually finish with an 800 grit. Experiment to find what suits you best.Discount store talc will do. Cheapest you can find .Baby talc is often the cheapest. Regards John
Liked by justintime2001
Hi, Can someone point me in the right direction as to which sanding sealer I should be using and a supplier please?
Also for best results what grit wet & dry should I use from & too?
