Clamp on prop-shaft grease nipple
Hi Colin.
One thing I forgot to mention, is that for some reason the holes in the prop tubes are not on the top, but half way round, which gives no clearance for soldering all around the brass tube.
Clamping seems the only option (unless I removed the tubes and start over again - a big job), where I can at least use flexible neoprene pipe for lubrication.
In any event, thanks for the suggestion.
Steve
