About the Waterline on Serenity
HI figtree, first float the hull in the bath, mark waterline at bow and stern, dry off then mount the hull so that the 2 arks are level, tape a soft pencil to a block of wood adjusted to the correct hight, draw round the hull to get the right line, mask the upper side of the line then paint the hull bottom, let dry overnight then mask the lower hull and paint the upper section.
To get a water line I use car lining tape (2mm) white. again following the painted line all round the hull, best if you lay the hull on its side, attach at the bow then unroll a length clear of the hull, lay the tape tight but not stretched direct onto the rear of the hull side, you wont be able to go from bow to stern in one go because of the undercut at the stern.
If not happy lift the tape and re-lay, once happy smooth the length of the tape with a soft cloth, once you have the waterline tape in place, overspray with clear acrillic either matt or semI matt, this stops the tape being scuffed on the dockside and when handling.
Hope this is clear
Etherow Model Boat Club
