@Karoq
Hi Karoq, perhaps I missed something or misunderstood—if so, please excuse me and disregard my comment.
I believe Fishercat, Toradog and DJW have already provided you with a lot of useful and precise information, but I would like to clarify one fundamental point.
When analyzing the characteristics of an electric motor (specifically brushed motors), in addition to other manufacturer specifications, you should consider three current values:
No-load current (also referred to as "idle current").
Load current (or "operating current"). When referring to the maximum value for which the motor is designed to operate continuously, the term "rated current" or "continuous current" is used.
Stall current.
No-load current (I0): This is the current drawn by the motor when it spins freely without any mechanical load applied to the shaft. It accounts for overcoming internal friction (in bearings and brushes) as well as iron losses. This is the lowest current value encountered during normal operation.
Load current (IL or In ): This is the current drawn when the motor is subjected to its intended working load (nominal torque). This value varies based on the effort required from the motor and serves as the reference parameter for sizing cables and thermal protection components for continuous use.
Stall current (IS): This is the maximum current drawn when the motor shaft is mechanically locked and unable to rotate (RPM = 0). In this state, the back-electromotive force (back-EMF) is zero, the impedance is at its minimum, and the motor acts essentially as a simple resistor—generating the maximum possible torque, but also the maximum amount of heat. If this condition persists, it can burn out the motor.
You should not take the no-load current into account, as you will never operate your model under those conditions. In the water, the current draw will always be higher (I personally measure current by placing an ammeter in series with the circuit while testing the model boat in a bathtub at various speeds, from minimum to maximum).
You should never use the stall current (which I suspect you might be doing now) to size your ESC and batteries—unless you are using a specific calculation or algorithm that treats it merely as a reference parameter. Stall current is harmful to the motor; you should never reach it, and if it does occur, it must be interrupted immediately via a fuse or some other protection system.
The current you should focus on is the "load current" or "operating current."
Often, however, this value is not provided alongside the other two.
In such cases, you can either apply empirical formulas based on the other two values (no-load current and stall current) or conduct practical tests—which, in my opinion, is the best approach.
What formulas can be used to determine the operating current?
As I mentioned, I prefer to run a series of tests under real-world conditions (with the propeller in the water at maximum speed) and then add a bit of extra tolerance.
Nevertheless, here are a few formulas:
If you do not know the torque of your load but want to determine the current at which the motor will perform best, you can mathematically calculate the "Maximum Efficiency Current", Ieff_max.
In the context of RC modeling, this is the true "ideal operating current"—the point at which the motor wastes the least amount of energy as heat, thereby offering maximum runtime and longevity. It is calculated by taking the geometric mean of the no-load current and the stall current:
Ieff_max = the square root of (I0 × Is)
• Practical example: I0 = 1.59 A; IS = 60 A.
• What does this mean? To ensure this motor operates at peak efficiency, you should select a propeller or gear ratio that results in a current draw of approximately 9.8 Amperes under load.
1.59 A × 60 A, all under a square root, equals 9.8 A—approximately 10 Amperes.
An alternative, simpler, and more empirical method:
If you are merely sizing cables or a battery and wish to avoid complex calculations, there are two widely used rules of thumb in the field of RC modeling for estimating the recommended continuous operating current:
• The 20–25% of stall current rule: A safe continuous operating current—one that prevents the motor from overheating—is estimated to be around 20% to 25% of the stall current. For instance, if the stall current is 60 A, the motor can safely operate continuously at approximately 12 Ampere.
• The "triple no-load" rule: For standard, high-efficiency brushless motors, the nominal operating current is often between 3 and 4 times the no-load current. If a motor draws 1 A at no-load, its typical operating current under an optimal load will be approximately 3 A – 4 A.
I have excluded any formulas that require knowing the operating torque or the stall torque.
While I don’t have as much practical, hands-on experience with brushless motors as I do with brushed motors, I believe that—despite some minor differences—the same principles apply to both.
If you’re interested, some time ago I compiled a collection of information and experiences (from myself and other model boat enthusiasts) regarding small, permanent-magnet brushed motors. Among other things, it includes the method described by RoyCV, which I have quoted verbatim, citing him as the source.
Here is the link.
https://model-boats.com/wiki/147457
