What do YOU think? Will it make a difference?
7 replies 21 likes 0 followers Last activity: 3 months ago
#8 26
@RossJ Sorry but a small thinking mistake here. The nozzles actually are more efficient on slow moving vessels such as tugboats when engaged in towage.
At higher speeds it is better to have free running props so the water runs unobstructed to the propellors.
That is also the reason that on todays modern azipod propulsors the props are actually pulling the ship instead of pushing.
Liked by chugalone100 and Chum444 and
#7 31
The nozzle will restrict the flow of water from the prop, that will increase the velocity hence faster vessel. It might not be as efficient going astern tho.
Liked by GaryLC
#5 34
Thank you for the link to the Kort article. My experience with steerable Korts on models is that when backing, the nozzle acts like an outboard does on a 1:1. I emphasize model since those of you with experience on 1:1 tugs may feel differently.
Liked by PeterN
#4 34
Nozzles have been used to improve on bollard pull however nowadays they are usually fixed around the propellor (Kort nozzle) . I have sailed on a supply boat which was equipped with steering nozzles. Makes for interesting maneuvering when reversing so keep that in mind.
It goes different then with fixed nozzles and conventional rudders since the thrust direction changes.
Have fun at: https://www.kortpropulsion.com/kort-nozzles/
Liked by SimpleSailor and chugalone100 and
#2 55
Ron, I’m looking forward to hearing about the results. That is really an interesting arrangement & would be a rather easy retrofit. I’m a strong advocate for steerable Kort nozzles which most all of my tugs have. I think I could predict the results but will await your report of the results.
Good luck!
Bill
Liked by jumpugly and muddy
#1 57
Beamsville has a Texas Nozzle attached to its rudder, says Marcel Theriault owner/Operator.
He said it provides better turning when towing.
I added a similar thing to my model and will see if there is any difference of control. I’m putting it in the water Aug. 9th at the Toronto event on Nathan Phillips Square reflection pool.
No, the nozzle does not encompass the blades of the propeller
The Beamsville
Notice the top of the rudder
Original rudder
Added to top of rudder too
Yes it clears the prop blades
Liked by EdW and chugalone100 and
