Glue removal.
Started by tim morland
7 replies 41 likes Last activity: 6 months ago
Glue removal.
There's a series On BRITT TV about these boats, https://www.google.com/search?q=british+narrow+boats&oq=british+canal+boats&gs_lcrp=EgZjaHJvbWUqCwgIEAAYFhgeGIsDMgkIABBFGDkYgAQyDQgBEAAYiwMY8gYY-gYyCggCEAAYiwMYgAQyCwgDEAAYFhgeGIsDMgsIBBAAGBYYHhiLAzILCAUQABgWGB4YiwMyCwgGEAAYFhgeGIsDMgsIBxAAGBYYHhiLAzILCAgQABgWGB4YiwMyCwgJEAAYFhgeGIsD0gEKMjQ2NzBqMWoxNagCCLACAfEFafKHG4QV3WTxBWnyhxuEFd1k&sourceid=chrome&ie=UTF-8
Liked by AlessandroSPQR
Glue removal.
Many thanks to all those who replied to my query about glue removal. I'm sorry that I haven't replied sooner but I greatly appreciate everyone's input. I use acetone for a lot of projects but hadn't thought to use it in this case. I'll let you know how I get on.
Best wishes Tim
Liked by AlessandroSPQR and hermank
Glue removal.
Yes, I agree with the other fellows—acetone does work, but it’s a very strong chemical.
In my case, I prefer using the Bob Smith Industries UN-CURE Super Glue Debonder. It’s much gentler and gives me better control when ungluing parts.
Glue removal.
Just keep in mind, that acetone is a more dangerous chemical than its common use in nail varnish remover and general household uses implies. Nitrile gloves, goggles and plenty fresh air are very much recommended, especially if you are using it on a regular basis like in a model boat workshop. Check the web for more specific information!
Ian
Glue removal.
I think that depending how big it all is you can put some gel nail varnish remover (gel type contains acetone) on a cotton pad. Wrap that and your fossil into a small parcel of foil leaving space for the fumes to circulate around the rock (foil helps keep the fumes in). Give it five minutes or so to soften and then try wiping the residue off with another lint free cloth that has nail varnish remover on it? Probably best if you don't let the impregnated cotton pad rest on the face of the fossil in case it doesn't all wipe off and to stop cotton wool sticking? You can get the remover at superdrug/Boots. Saw some gel nails removed this way which is what makes me think it would work. I use the stuff to get superglue off my fingers when building.
Glue removal.
Acetone is the solvent I have in my kit. Works a treat to dissolve super glue. I presume it's the residue you want to remove rather than releasing the pieces and that could be tricky as the acetone evaporates very quickly.
Anyone else have thoughts on this.
Glue removal.
Super glue can be removed using acetone, isopropyl alcohol, vinegar, oils, or mechanical methods, depending on the surface type.
General Guidelines
Super glue, or cyanoacrylate, bonds extremely quickly and strongly, making removal challenging. The method you choose depends on the surface material and whether the glue is fresh or dried. Always test any solvent on a hidden area first to avoid damage, and use protective gloves and ventilation when handling chemicals like acetone.
Reader’s Digest
+1
Removing Super Glue from Skin
Warm, soapy water: Soak the affected area for 10–15 minutes to loosen fresh glue.
1
Acetone-based nail polish remover: Dab gently with a cotton pad to dissolve dried glue.
2
Oils: Olive oil, baby oil, or petroleum jelly can help soften glue without harsh chemicals.
1
Peeling: Once softened, gently peel or roll the glue off. Moisturize afterward to prevent dryness.
1
2 Sources
Removing Super Glue from Non-Porous Surfaces (Glass, Metal, Ceramic)
Acetone: Saturate a cotton ball or cloth and press onto the glue for a few minutes to soften it.
1
Scraping: Use a blunt, non-metallic tool like a plastic scraper or old credit card to lift the softened glue.
1
Alternative solvents: WD-40 or isopropyl alcohol can also help loosen glue on these surfaces.
2
Clean-up: Wipe the area with a damp cloth to remove residue.
1
3 Sources
Removing Super Glue from Wood or Textured Surfaces
Sanding: For stubborn dried glue, gently sand the area to remove residue.
1
Warm, soapy water: Can help soften glue on unfinished or sealed wood before scraping.
1
Acetone caution: Avoid acetone on finished wood as it may remove varnish or paint.
2
4 Sources
Removing Super Glue from Plastic or Painted Surfaces
Mechanical methods: Carefully scrape with a plastic tool to avoid scratching.
1
Oils: Vegetable oil, mineral oil, or petroleum jelly can lubricate and loosen glue without damaging the surface.
1
Acetone caution: Acetone may dissolve or discolor plastics and painted finishes, so use sparingly and test first.
2
2 Sources
Liked by AlessandroSPQR and tim morland and
Glue removal.
Hello everyone from a cold and windy UK,
My problem is not strictly about boats but could have a relevance. One of my hobbies is fossil collecting, I was repairing an ammonite (calcite, limestone, calcium carbonate) the other day with super glue and managed to squirt the glue allover the face of the fossil. My question is this.
What solvent dissolves super glue? Scraping it off is not a possibility.
I look forward to any replies.
Best wishes Tim
Liked by AlessandroSPQR and RodC and
