I used the "grain of wheat" bulbs that came with the package deal that included the trawler. I should have known better. Perhaps back then the LEDs might not have been small enough for the fixtures. Can't remember. Anyway, I never used the lights except for the initial test. So my plans are to toss the "C" cells idea, and switch the NImh battery with a li-ion pack thus saving weight and devote the weight reduction to ballast low in the hold.
Attached are some of the "night" photos with the lights on.
[{"id":"177403792066","name":"177403792066","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403792066\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403792066\/s","isImage":false,"ext":"file"},{"id":"177403793199","name":"177403793199","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403793199\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403793199\/s","isImage":false,"ext":"file"},{"id":"177403794235","name":"177403794235","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403794235\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403794235\/s","isImage":false,"ext":"file"},{"id":"177403800412","name":"177403800412","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403800412\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403800412\/s","isImage":false,"ext":"file"},{"id":"177403802520","name":"177403802520","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403802520\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403802520\/s","isImage":false,"ext":"file"},{"id":"177403804041","name":"177403804041","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177403804041\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177403804041\/s","isImage":false,"ext":"file"}]
Are the lights LED or bulbs? Either way, you could save some aggregation of removing the alkaline battery pack and replace the connection to your bec on the receiver. A resistor may be needed but that can be determined.
Your conversion is similar to what I have had to do with the kits given to me. Not impossible to achieve, it just takes some imagination, research , and patience.
Ron
I started taking things apart on my trawler to get to the inside. This is a very short video showing some of the prep work to get at the inside of the hull. You can also see some of the extra details that I added.
https://youtu.be/cdliXjloYXE
[{"id":"177398798158","name":"177398798158","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177398798158\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177398798158\/s","isImage":false,"ext":"file"}]
Thank you Lew!
It was what I was expecting and you did a super job. I like this balanced rudder layout a lot, because it us inherently robust and tough.
Thank you Lew!
(I tried to post a photo of the rudder and prop but apparently the gallery comments are for text only )
Here is the photo of the prop and rudder. The prop is probably a little oversized for this kind of boat making it a little fast. So, I just need to ease up on the throttle.
As for the rudder, the axis is about 1/3 the way back as I explained in the comment. This really handles well.
[{"id":"177372727311","name":"177372727311","caption":"","url":"https:\/\/beta.model-boats.com\/media\/177372727311\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/177372727311\/s","isImage":false,"ext":"file"}]
