How to secure acccess deck covers /hatches
Started by bruced
11 replies 40 likes Last activity: 8 months ago
#12 1
Hi Ronald,
I like the push pin idea shown here on the Garry Web video that you provided the link for - there are some applications where this could be very useful.
Liked by hermank and Ronald
#11 1
This is exactly the stuff. I have never had problems with it. Its cheap and can be used for other things (sticking things to walls and not leaving stains). It sticks well and can easily be replaced. It seems to loose its stickyness with oils or dirt contaminating it. Obviously it is not suited to continuous underwater useage but it does withstand occassionally get wet
Liked by Ronald and hermank
#10 1
Bill is the Blu Tack you are referring to the same as this shown?
Key details regarding Blu Tack and water:
Water-Resistant Properties: It is a non-soluble, synthetic rubber compound that can withstand exposure to moisture without breaking down immediately.
Best Use Case: While water-resistant, it is designed for, and performs best on, clean, dry surfaces.
Limitations: While it resists water, it is not designed to be a permanent, fully submersible waterproof sealant, but rather a reusable adhesive for holding items in place, even in damp environments.
Composition: It is denser than water and is non-toxic.
Wikipedia
Wikipedia
+4
Note: Some product listings may specify it is not for high-moisture/submerged applications, but for general, daily, non-porous applications.
Bostik
Liked by chugalone100 and EdW and
#8 1
Very nice this is my kind of boat .
Have you thought about magnets you can buy very small ones o ebay depending how well you hatches fit depends how big magnets you can buy , i have used for many different things from hatches to fitting people on board
Philuk👍
Liked by AlessandroSPQR and DWBrinkman and
Bruce1946, I suggest you try ShoeGoo. I get mine at WalMart, in the shoe dept, on the rack where you find shoelaces and shoe polish. Or there is GOOP household cement.
If you attach with double-sided tape you may find the magnets so strong that they pull off the tape. There are vastly difference double-sided tapes out there.
To decrease the strength of magnets just put a disk of clear plastic on the mating surface. I use the plastic, clear, from the sandwich boxes from the deli.
Another option is velcro and it's great becuz you can vary the strength of the join just be using smaller or larger pieces of self-adhesive velcro from the dollar store (white or black, quite inexpensive)
These are not my own original thoughts, I've been in our hobby intensively for only 4yr and I learned these things from the cluster of mentors I hav encountered. Great hobby for us retired folk, for the friendship & camaraderie.
Rod of MMM in Toronto, Canada
VA3ROD
Liked by Steves-s and pressonreguardless and
The problem I'm having is adhering the magnets to Styrene. CA glue and epoxy do not adhere to the surface of the magnets! GRR
Liked by hermank and chugalone100 and
Zooma:
I used magnets on my fireboat too, but my hatch was made from a piece of galvanized sheet. What material did you use for yours?
Hi bruced,
I would suggest the use of small high power magnets.
These were used on my scratch built TID Tug and they worked very well.
Thunder Tiger used them to hold the hatches down on the Avanti fast power boats that I enjoy running so much, and they secure the hatch perfectly even during high speed racing .......and allow the hatch to be lifted off so easily when changing a battery in-between runs.
I also use these same small round magnets to secure the top-deck on my various r/c model tanks as I much prefer them to the number of screws the manufacturers tend to use as this make's changing the batteries and making any repairs a lot longer than they need to be.
What's a good way of securing access hatches on a 39 inch tug. for easy access? This is my BC Sea Hawk I have been working on for about 8 months now. I'm Almost done, ( 2 large access hatches in aft deck for Z drive Access)
Also suggests on securing cabin.
Liked by PhilH and EdW and
