2nd voyage on Lake Paterno of the 1:60 scale model of a schooner-armed steam gunboat, assisted by a
You're right.
Only one relay of this type is enough. The second is useless.
I redid the drawing.
The question was in message #35.
I didn't translate all the parts of your reply correctly, but I get the general gist.
The diode on the coil is absolutely necessary (unfortunately, I know the reasons why it needs to be there). You're right about that too, thank you so much for reminding me.
Regarding the sentence: "Most importantly, the coil energizes at 6 volts and can handle 40 amps."
It's clear, there's no doubt about it; the 40 amps certainly don't refer to the current flowing through the coil.
Very little current flows through the coil; in fact, it's managed by another circuit (the on-off switch that manages a low current). Moreover, those coils have very thin filaments.
The 6 volts refer to the coil's excitation voltage, and the 40 amperes refer to the current flowing through the switch controlled by the coil.
Sorry, I took that for granted.
Thanks also for the invaluable advice on the relay type. This certainly avoids the need for a second relay.
Do you think the relay I linked is "Break before make"? I think so, but I haven't been able to figure it out.
I wanted to ask if the circuit is OK as it is (see the new attached drawing), but more importantly, if this relay is correct, or which relay you would choose.
Could you tell me (if you don't have a reference model or type) just the general specifications?
