Epoxy over paint does it work?
Using silicone to join these two halves together works well - and of course - also makes a good watertight seal!
Most of these boats are quite old now, so when one comes along for restoration and needs taking apart to gain access, the first job is to cut into this seal to separate the joint and clean it up ready to be resealed after any necessary work is completed.
Cutting away the old silicone with a sharp Stanley knife is not at all easy as it makes a formidable bond that many years later is usually very much secure, so I have seen no evidence to date that silicone rubber is not a good adhesive/sealer to use in a model boat.
Obviously the strength of the bond depends on good preparation and how well the silicone was applied, but for joining the two glass fibre halves of the Spearfish together, silicone rubber appears to be a very good choice.
I have no experience of bonding wood and brass tube together (as in sealing a prop shaft into a wooden hull) but it sounds like it also works well and may be worth a try as it could also dampen some transmitted vibrations and make for a quieter boat.
…but taking note of RodC’s caution, no electronics should be added to the boat until after all the vapours have disappeared completely to avoid damaging them.
