Pats QOD 24/06/25
But the answer I was looking for is as follows :-
When the cracks were first detected the action was taken immediately in order to mitigate the problem from getting worse before the next refit was due
(Personally I wonder if this was the reason the whole class was sold off in the early 90's - it may have cost a huge amount of money to cure the problem completely - also the FI Conflict proved that aluminium and steel was not a good combination on ships).
Restrictions put in place only to be ignored in time of war
1. Ollies to be run at no more than 80% of capacity (Set lever 8 - 0)
2. Maximum amount of rudder to be used is 20%
As I said probably only drilled into you as a watch keeping officer or on duty in the SCC.
On a personal note I think the T21 was one of the best looking warship the UK ever had with the original Daring Class coming a close second YMMV
