Len1. My post could be misread by someone. From previous posts in this thread other FlySky TXs have mixing functions. I was only referencing the 3 channel TXs. Even then, as you know, there are other options for mixing functionality on a 3 channel TX.
The three channel FlySky is a fine TX & a great value for those just entering the hobby.👍
What Kind Of Tranmitter Do You Use and Why Did You Choose That Type
Chum444, I think I must add a qualifier to your statement about the fact that the Flysky radio's don't work on more than 3 channels or have mixing functions. I think this may only be true for the 3 channel pistol grips because the FS-i6X and FS-ST8 and other upper range receivers certainly do.
You can not beat Flysky for quality for the buck. I use them for my boats as well as my 1/14 scale trucks
Len
Len
I also have a couple of FlySky 3 channel pistol grips. They are inexpensive (including their rx’s), reliable, & have many programmable functions; end points, expo, differential, etc. Another plus is their multi channel rx’s are compatible with my FrySky that’s equipped with a multi module. The FlySky performs well for boats that don’t require more than 3 channels or mixing functions.
This question comes up every now and then on this forum. I stand by my Flyskys, all of them. I have Futabas, a Specktrum, and a bunch of others. The FS-I6X stands out as the "best bang for the buck" (pound, euro, or whatever).
Florida 😎, USA😍
Florida 😎, USA😍
FS-i6X 10CH 2.4GHz RC Transmitter Controller with FS-iA6B Receiver Upgrade Cable for RC Boat $60 off amazon ( 40-45 quid)
Cheap and effective 6-10channels and can store many model configurations as well as telemetry capable
works😁
works😁
Thi is a reply to Chief from a few weeks ago. It looks like the Radiomaster does support several HiTec protocols, if you google “4 in 1 protocol list” you’ll see the supported protocols.
I still have my Taranis QX7, I keep if for a backup in case something happens to my Radiomaster. My QX7 has a plug in multi module in the module bay, so it supports different protocols too. The QX7 and my Radiomaster have completely spoiled me.
With two exceptions, I use FrSky radios. I have X9E and Tandem XE radios. Why? Because of the huge number of switches available for animation, the unlimited assignment abilities, the unlimited mixing capabilities, general quality, and price. I can spend quite a bit of time singing praises about them, but i would be off key.😊
Not exactly radio related but I picked up these receiver boxes from Temu. Water tight if you seal the servo cable exit.
[{"id":"175122669485","name":"175122669485.jpg","caption":"","url":"https:\/\/beta.model-boats.com\/media\/175122669485\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/175122669485\/s","isImage":true,"ext":"jpg"}]
I use a Radiomaster 16S. It has memory for more models than I will ever need, an os called OpenTX, (now Edge), and it comes with a the 4in1 chipset. There are 4 chips on in the transmitter that allows me to bind to around 90 percent of the receivers out there...FrSky, Flysky, Spektrum, Futaba, etc. That allows me to buy good used receivers of most any make and saves me a bit of cash in the process. Also, I can wipe out any function in the transmitter and assign it to another switch, slider or stick. If i have a 4 channel receiver, and I want to use say, channel 3 for a light switch, and i want to use a 2 position switch on the transmitter to control it, I just go into the menu, find the stick that controls Channel 3, and assign that switch to it. Plus, multiple mixes, curves, things Ill probably neber use but there if I need them. And it's been rock solid so far.
I recently bought this radio from Temu as at £4.70 it would be stupid not to try it out.
The normal price is £15, which is also very cheap.
It’s not great quality but works well and has 7 channels.
The receiver has normal servo outputs as well as a couple of two pin outputs for lights etc.
It is designed for cars or trucks but I tested it in a boat and it worked well.
[{"id":"174875969270","name":"174875969270.jpeg","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174875969270\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174875969270\/s","isImage":true,"ext":"jpeg"},{"id":"174875969488","name":"174875969488.jpeg","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174875969488\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174875969488\/s","isImage":true,"ext":"jpeg"},{"id":"174875969552","name":"174875969552.jpeg","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174875969552\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174875969552\/s","isImage":true,"ext":"jpeg"}]
I started with a Flysky then tried a Radiomaster but could not get on with Edge/TX so went to FRSky using Ethos - by far the best radio system I have seen so far but as said they are not cheap
FRSky are also dual band 2.4GHz and 900
One of my radios is a Spektrum. The boat sank and after cleaning it out (including the receiver), the receiver was dead, still after a week. I bought a replacement, but I gave the receiver one last check after two months and it worked!
The Spektrum transmitter is pretty solid, a lot heavier than the Flysky.
Can't say the Spektrum is inexpensive, probably about 4x the price of Flysky.
Florida ⛱️, USA 🇺🇸
Florida ⛱️, USA 🇺🇸
I use Spektrum dx7. Its reliable and if it gets water in it, the bits are cheap to replace! (With the mod to the voltage regulator, I get about 5hrs power up time, for each charge cycle!)
Give a man a fish, and you feed him for a day. Teach a man to fish, and you get rid of him for the weekend.
I have a range of transmitters and each has its pros and cons.
Taranis X9
Spektrum DX6
Futaba FF7
Futaba FP
Futaba 27Mhz
The quality of the Futabas’ is far better than the rest.
Taranis X9
Spektrum DX6
Futaba FF7
Futaba FP
Futaba 27Mhz
I have and use two Taranis X9D Plus. One runs Open TX and the other Edge TX. The Edge TX has a multiprotocol module. I also have a Radio Master Boxer running Edge TX with multiprotocol built in and I have a spare Flysky i6 which I now use only on the rescue tug.
I have a variety of RC transmitter/receiver radios. The most common ones are the Flysky i6x six channel systems. The are a great value or as we say here (US): "a great bang for the buck".
Florida ☀️, USA❤️
Florida ☀️, USA❤️
