HMS Brave Borderer PT1011
Started by ChrisJ2
8 replies 27 likes Last activity: 1 year ago
Sorry for the lack of updates, Been crook as last couple of weeks,
Well most of the bottom is sheathed with plywood now the exciting task of sanding before fiberglassing and fairing. Watch this space Lol.
Liked by SouthportPat and alexandre
An Early photo of PT1011, Will add more as progress is made
Be kind I am a novice Lol
Liked by alexandre and SouthportPat and
I was running a 1/24 S-Boot 3 props/ 3 MFA
850's came down to 1 prop 1 brushless just as good.
Liked by SouthportPat and alexandre and
Ah, I didn't realise you were going to use a gas engine. Hope you've got a gearbox that's up to the job. Sorry, I'm unable to advise on the props.
G.
Liked by alexandre and Len1 and
I am planning to use a 29cc 2T gas engine, Am thinking may I should go for 45mm props, Thoughts please. Thanks for your input Gordon
A 1.5m Brave Borderer is going to need a powerful motor if it's to drive two props through a gearbox. Is there no way you could use two motors, then you could space the shafts as far apart as you like?
G.
Liked by ChrisJ2 and hermank and
Thanks' Doug,
I remember reading somewhere that the space between props should be 1.5-2 times the diameter of the propellers, which calls for a minimum of 82.5.
Thank you for the reply
Liked by hermank and Len1
Hi Chris,
Don't see your problem🙈
If you put two 55mm props tip to tip the distance between their centres will be 55mm.😉
So you will have 78.6-55=23.6mm between the prop blades when the shafts are fitted to the gearbox.
BTW: Our Brave Borderer guru is a great builder and 'good bloke' from Canada.
User name 'Rowen'.
Check out his Brave Borderer Build Blog at link below.
https://model-boats.com/blogs/40884?sort=ASC
Hi All
I am building a 1.5Mtre PT boat, Running twin props, My problem is my gearbox is 78.6mm centre to centre running twin shafts with 55mm four bladed props. if I run them parallel I will not have enough distance between the props.
My question is would it be possible to run them in a slight "V"
TIA
Liked by Len1
