How to fix torpedos
How to fix torpedos
Alan
How to fix torpedos
If you can get to the under deck area inside the hull, you could fit the cradles with 2mm treaded rod through the deck and secure with nuts and washers, to hold the torpedoes in place, small stainless or brass screws fitted up through the cradles, small screw dab of matching paint, hay presto it vanishes, also giving you piece of mind if you want to repair or up grade the weapons fit.
How to fix torpedos
Liked by
Loading…
