Its looking good and very fiddly work. I am working on the canopy on my Venice water taxi and I recently machined 4 .036 thousands dia pins to pivot the canopy frame which is 2 mm dia brass rod. Needed to use a very sharp HSS tool to machine them. Photos to follow at some stage. Thinking outside the square as to what material to use is also a challenge. I needed 2 stainless air scoops for the vents on my engine cover so I bought 2 SS teaspoons and cut about 12 mm off the spoon end. Perfect is what I would say. Cheers Ian
Jumpugly sharp is the word till I sanded it all down last night and now nice and dull to the touch just a bit of fettling to do then what to stick the plastic screen onto the metal with was going to use double sided clear tape instead of glue
So that was a productive 2 days with the project windscreen frame it’s taken one muck up to get the final frame right with a little dremmel fix here in the there and not bad what you can do with a £14,99 pedal bin from the range
[{"id":"174326826399","name":"174326826399","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174326826399\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174326826399\/s","isImage":false,"ext":"file"},{"id":"174326826483","name":"174326826483","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174326826483\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174326826483\/s","isImage":false,"ext":"file"},{"id":"174326826429","name":"174326826429","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174326826429\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174326826429\/s","isImage":false,"ext":"file"},{"id":"174326826580","name":"174326826580","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174326826580\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174326826580\/s","isImage":false,"ext":"file"},{"id":"174326826548","name":"174326826548","caption":"","url":"https:\/\/beta.model-boats.com\/media\/174326826548\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/174326826548\/s","isImage":false,"ext":"file"}]
