Action P94
Started by Nickthesteam
5 replies 28 likes Last activity: 1 year ago
Action P94
Job done! All wired up and working well. Shafts need greasing but I will wait until the paint job is done befor filling with lithium grease.More photos and info on LCM6 build thread. There is a lot to fit in a very small space..
Liked by Doogle
Action P94
Cheers Doug. The channels I have used are 3 = right stick for throttle 4 =left stick for steering. I know it's an odd set up but I can re jig once I get it going. (I tested with the rudder servo to id which is which...
Action P94
Thanks Nick👍
If you don't want to use a separate RX battery then just reconnect ONE of the red wires from the P94, but NOT BOTH😉 and all should be well.
Unusual channel selection on the RX though!
I prefer to use stick controls Chs 1 and 2 or 1 and 3 for motor and steering.
Let us know how you get on.
Liked by Doogle and Len1 and
Action P94
Hi Doug. Hope these photos are clear enough. I was wondering where the power to the receiver was coming from with no +V connected, I didn't want to try anything drastic in case the magic smoke appeared!
Liked by roycv and Doogle and
Action P94
Hi Nick. Yep I do know the difference, thanks for asking😁
Seriously though folks ...
First off - BOTH P94 and P94L versions have a BEC output, 5V 2A.
Second: Re "I followed the instructions and removed the red wires from the two plugs that connect to the receiver".
Begs the question - Do you have a separate RX battery?
If not then you have disconnected the BEC supply from the P94 and the RX has no voltage supply, ergo 'Not a peep'🤔
Third: the physical differences are:
The P94L is the 'Lite' version with 10A rated FET output transistors per ESC.
The P94 has different FETs rated at 20A and needs two heatsinks which stick out through the lid of the case. See attached pics.
Please post photos of your version and wiring, or a wiring diagram / Sketch.
Action P94
Hi, does anyone know what the physical difference between the P94 and the P94L dual esc from Action is? My example has P94 on the label and instructions for P94L. I know the 94L is the bec version. I followed the instructions and removed the red wires from the two plugs that connect to the receiver and connected up as per the instructions. Nothing, not a peep. Any one have any thoughts?
