stupid question
stupid question
This is my two pennies worth,
I have always worked on the principle that the yellow is the Pos and the blue is the Neg and go to the motor, on some not all motors you may see a red dot next to the terminal this is the Pos side of the motor, if you look at a three pin plug the blue is the Neg,
As to what is a male connector or what is a female connector that is easy, a male always goes into a female
Fred
stupid question
If you don't know how to distinguish female connectors from male ones, don't worry.
If you want you can post a photo of your Esc and we could repost it with captions on each cable. I believe we would be able to do it, at least we will try.
However to date I have not seen any manufacturer use the thick yellow and green cables for the battery side.
If the ESC has large yellow and green cables (even more so with female bullet connectors) I would bet that those should be connected to the motor.
stupid question
Correct and precise information in my opinion.
I can add a detail that might be useful to you.
The connectors that go to the motor, since they supply current with invertible polarity, (unlike the red and black ones which draw current from the battery with pre-established fixed polarity) are female.
This is to prevent short circuits from accidental contact.
So (barring assembly errors, which are quite rare and unusual) the big cables with female connectors go to the motor. Most of the time I'm bullet type.
Most often, but not always, the battery cable connectors are Tamiya.
The three wires (which come out of the BEC of the ESC) and are used to receive commands from the receiver and power it at the same time are much thinner and have typical connectors (compatible with the pinouts of the receivers).
stupid question
Are you talking about 3 wires? Are you using a language translator?
Somewhere in Florida, USA
stupid question
In my case I Googled the Viper Marine ESCs (is yours one of theirs?) and downloaded the manual. In addition to what I said it states that the Blue = Motor negative and Yellow = Motor positive.
But this may be different from manufacturer to manufacturer and hence why we need to know what yours is!
If you get the blue and yellow the wrong way round nothing bad will happen apart from the motor running the opposite way though brushed motors can run one way better than the other.
stupid question
stupid question
If you are referring to a brushed motor speed controller then the usual configuration for the wires are:
1. The plug that goes into the receiver
2. A switch
3. A red and black lead that go to the battery red to positive and black to negative. Don't for get your fuse.
4. The blue and yellow cables go to the terminals on the motor and swapping them will reverse the direction of the motor.
Hope this helps
stupid question
Liked by
Loading…
