Dusseldorf Fire Boat
It looks like a lovely model , pity the photo wasn't three times the size.
There's no way this can be determined by a forum post. Every model is different: Current waterline determined by materials used for construction and equipment on board.
The only way to do this is install battery's, fuel etc., and place the model in a tank filled with water. Then place small ballast blocks in various places on the deck to bring the model to the correct heel and waterline. Take the model from the water and glue or secure the ballast blocks in the hull in exactly the same internal position.
To make this accurate, for models running on liquid fuel, the tanks should be at the balancing point, not to far forward or aft. This will allow the model to rise out of the water correctly as the tanks are drained.
