Rustoleum Pain Can Nozzle Restoration
Started by LewZ
10 replies 37 likes Last activity: 3 years ago
I had this problem many times, there are many good fixes. My solution was to contact Rustoleum by email they sent me a whole bunch of different types of spare nozzles for free.
Liked by Colin H and LewZ
Back in the 'old days' these were the tool of choice to painters everywhere.. (for kerosene blow lamps) the wire is just small and stiff enough to tease the clog cr?p from a paint can nozzle!
May4th be with you!
Liked by Captainnick and Colin H
SOAK-SHAKE-REPEAT. Sounds like how I wash the dinner dishes. THE ADMIRAL doesn't approve, though😉
Good tips - and I like Colins idea of saving old nozzles after the cans are empty! (something I have done many times over the years!).
I sometimes drop the dirty rattle can nozzle into a small screw top jar (like an airbrush storage paint jar) part filled with thinners - and give it a good shake .
This agitates the clogged paint (after it has had time to soak) and can save risking any damage to the nozzle if you don't have the correct size drill bits to open them out accurately.
Soak - Shake - Repeat. This process can be repeated several times until the nozzle is clear and doing more than one nozzle at a time (if your jar is big enough) helps the agitation and can save time if you have more than one blocked nozzle.
Liked by Captainnick and Colin H and
When I use Rattle cans and I have finished spraying I turn the can upside down and continue to spray into the booth until the spray is clear. Have not had much trouble with the nozzle clogging since doing this.
You probably do this anyway.
Liked by Colin H and Len1 and
That's a helpful tip Lew.
Whenever I use rattle cans I re.ove the Nozzle after each use a put in a jar of cellulose thinners till next needed, then blow through with airline before use. I even keep nozzles from empty cans the same way so always have a few spares.
Liked by LewZ and Len1 and
Alternate: You can also buy these nozzles in a package, not cheap and not on the store shelf. (Amazon, eBay.) Lew
Liked by jumpugly and Colin H and
Yessir, the story of my modeling life as well. Thank you for the bit size you use Lew.👍
Liked by Colin H
Another good LewZ idea!
Thankyou LewZ, us Canadians are "bilingual", we speak both fractional/decimal inches as well as METRIC, so your dimensions are well understood North of the "longest undefended border"
OH! CANADA!
VA3ROD
This happened to me several times so I thought I would pass this tip on to you all...
Lazy, forgetful, or it just happens, I get some of my "rattle cans", in particular here Rustoleum brands where the little plastic nozzle gets clogged. So, here is what I do to clear the clog:
☹️Pull the nozzle up off the can.
🤣Soak overnight in paint thinner.
🤓Use a .125 inch diameter drill bit to clean out the paint on the inside (do not drill through).
🤓Use a .030 inch diameter drill to clean out the nozzle hole to center hole. (do not drill through).
🤓You might need to repeat drilling steps several times.
😮Blow out any particles.
😉Replace nozzle (not to hard to avoid accidental spray).
😊After this I have not noticed any difference in the spray pattern - works great.
Florida 🌩️☹️ today, USA
Liked by flaxbybuck and DuncanP and
