Brushless motors -Help!
That would explain the prop size suggested. For performance brushless is the best solution. if you can build the model to be lightweight then you may not need very large motors. Regarding weight its the extra bits you add that can really add on to the overall weight. Light batteries will also help and whilst a large SLA will provide the power it comes at a heavy weight cost, plus the sheer size can make selecting the best position in the model difficult. Any weight forward of the motor will have to be lifted by the model before it will get on the plane and this is often the reason why some boats don't perform well.
You do not need to use racing props and for scale appearance 3 bladed brass props look the part and will perform well at scale speed. I would be looking at 40mm /- 5mm as a starting point 😀
