led lights
Followers (8)
- luckyduckBronze
- EdWBronze
- RNinMunichBronze
- GregHiltzGold
- Stephen TGold
led lights
led lights
led lights
Don't apply a battery directly to the LED, it will destroy it. You need a current-limiting resistor, occasionally referred to as a ballast resistor, I wud suggest a minimum of 68 Ohms or 100 Ohms. That's for a quick test. For a permanent installation you will want to select the resistor value to give you the desired brightness.
Red LEDs require the least voltage, other colours require more, & a white LED needs a bit over 4V to "ignite".
led lights
Some LEDs have one wire longer than the other.- longer lead is often the pos.
The wires can usually be stripped with a thumbnail or small blade.
I solder the leads, then cover with small heat shrink tubing.
led lights
led lights
led lights
next how do you strip them
and join them
help please
Liked by
Loading…
