Water cooling advice
Started by HappyHaggis
7 replies 14 likes Last activity: 3 years ago
I use a micro air/water pump on my subs to blow ballast tanks on model submarines. It is very small and is equally able to pump air or water. Cost about $15 usd at NautilusDrydocks.Com. Might be worth taking a look to see if it will work for you. Search for micro pump in the shop section of web site.
Hope this helps,
Steve R
windwardcd@gmail.com
Liked by HappyHaggis
"The next thing I'd like is one that runs intermittently like on off on off on off to replicate a real boats exhaust at idle. "
I might suggest adding a riser to the exhaust pie. As the pump pushes H2O up the inboard side of the riser, it finally crests over the top of the riser and spills out the exhaust outlet. The pump meanwhile refills the inboard side of the riser until the H2O again spills over. Very prototypical hopefully. I've never tried it, so let us know if it works.
Liked by Graham93 and HappyHaggis
I bought my pumps off AMAZON.CA, both just the bare pump & also a version that includes a switch. Sorry I don't know how to attach a direction, or link, to the product. But i hope this helps.
VA3ROD
Liked by stevedownunder and HappyHaggis
I believe the on /off would be a separate channel on the radio. I have purchased a small water pump off ebay. It was 7 volt, but I think you may need a valve on the out put. This way you could throttle the output to make it look realistic or a large line on the output side to make it sputter and fart realistically.
I think the valve would give you more options for output. The more experienced folks could give you more info
Good evening
I am looking at ways to have constant water cooling so when I'm idle water is still going round. I'm looking for a very small water pump though can't find one.
How would I go about getting a pump to do that? A bit like flicking a switch back and forth however having that done automatically
Thank you
Scott
Scott (Haggis)
Scotland
Liked by stevedownunder and Colin H
