Hi Fulvio,
Strictly speaking a brushed motor should not affect a quality 2.4GHz receiver, especially if it is mounted as far as possible away from the motor and motor supply wires.
It has been reported that brushed motor interference may also affect some ESCs and even servos! Especially with 'cheapo' ESCs and Servos and if their signal wiring is run close to the 'dirty' motor wiring.
BUT! Some of us (especially submarine drivers) still use 40MHz sets which can be badly affected by brushed motor interference. Reason is that 2.4GHz is not effective underwater🤔
So as a precaution and courtesy to other users nearby suppression capacitors should be fitted.
Click on the pic in the article to enlarge it and you can then read the values.
They are 1 x 0.047µF and 2 x 0.1µF (microFarad).
Principle is the 0.047 between the terminals collects the spark energy from the brushes (like spurts of water into a bucket) and the two 0.1 caps bleed the energy away to ground. Like two leaks in the bucket
In this respect it helps if the motor case is connected to the negative side of the battery supply (ground) and even better if this negative ground is also connected to the propshaft tube which can contact the water.
The capacitors should be of the flat ceramic type, NOT tantalum types as they are polarised (+/-) and will pop when you reverse the motor💥☹️
Most model shops sell suppression kits of the three capacitors.
Krick here in Germany for example -
https://www.krickshop.de/Electronics-Motors/Engines-Electric-Motors/Electric-Motors/Accessories/Electric-Motors-interference-set.htm?shop=krick_e&SessionId=&a=article&ProdNr=42128&p=357
