Questions on identifying the make of the engine, make of boiler and the make of the fuel tank. And w
Followers (2)
- NickthesteamSilver
http://clevedonsteam.co.uk/
Questions on identifying the make of the engine, make of boiler and the make of the fuel tank. And where to get parts.
The boat is a lady Jane Maxwell Hemmings kit fiberglass hull(I believe in the early 90’s).
Looks like butane fired with a pressure regulator to control the flame once reaching the operating pressure.
The butane tank is missing the filler plug. Just need the manufacture of the tank or where I can get a replacement.
The engine is a two-cylinder oscillator with a fed pump running of the side. The feed pump is not connected. I would like to know the manufacture of the engine and if the feed pump was a option for this engine.
The boiler may have a ceramic burner as I did not take it parts yet.
Would like to know the manufacture of the boiler.
Looks like the fuel tank, boiler and engine all use the same type of valve handles which may lead to the same manufacture for all.
I did find an adapter as it looks like something to fill the fuel tank. Also found something that looks like a funnel that was under the steering wheel.
Everything looks in good condition as it has some dust from being on a shelf. The radio is a old Nautical Commander and will be replaced.
So, if someone could help with my questions above that would be great.
Liked by
Loading…
