arial on 2.4 hand set
Started by Stephen T
17 replies 23 likes Last activity: 4 years ago
After 8 decades I should write a book. Haha. Funny just remembered when I lived in Puerto Rico JB early 2000 flying every Friday n Monday back n forth to Boston. I was building a Viking ship. On the plane ride I would build the oars. Sanded n carved them in first class. I would also fly Rc at a paved field n learned to fly Rc Helis there. Boats n planes so many years. My navy time too I built ships while on a ship. Well I’ll post my progress on my ship building. Maybe it will help others too. Cheers
Howard hager
Liked by Colin H
Hhager2.
Could you start a blog on your build with its own heading.
Liked by fireboat
I’m starting the cabin parts. Creole Queen paddle wheeler. However, I can’t find a drawing of the cabin sheets to punch out. Does anyone have that page? Can you take a pic? I threw old set from last build n bet it was in pile.
Howard hager
I have had on order for two years from scale shipyard the USN Garcia DE 1040. Was on that ship in 65-67. We went to Uk london and Manchester. I have smaller models of it but wanted the 5 ft hulk to do a really detailed one from personal photos. We were with the Drente Dutch and Agincourt UK ships on NATO tour. I was told maybe they will have it done for xmas. Delay due to Covid n moving his shop. I hope the paddle wheeler is done by then. I’m going in garage n do water proofing of inside the boat body. Cheers
Howard hager
Liked by Colin H
Have the extra lifts in place I took pic n also one with deck parts just laying on them. A few filler patches n ready to fiberglass.
Howard hager
Liked by RodC and Colin H
I’ll use 1/2 pine strips on the shear will raise the platform to glue the deck on. That will add height so it will sit higher in water. I’m going to seal the body inside with acrylic minwax blue spray can. If I need to sit lower in water I can add weights. The Dumas creole Queen stern wheeler is a lot of wood, carving n sanding. The quality wood is great. Lots of left over scrap. It will have a 6 ch spektrum radio n a metal gear digital Servo to drive the rudders.
In pic is the boat body I placed the pine blocks to see how deck will sit.
Howard hager
Liked by RodC and Colin H and
Hhager2, I am trying to follow you on this, some pictures would make it easier for us to follow .
Liked by RodC
I’m getting to that point. Building the creole queen Dumas paddle wheel ship now body done but I’ll adding 1/2 inch to raise the main deck. I’ll fiberglass this body frame before adding the main deck. I’ll add doors to the cabin structures this time. Also smoke n new engine drive belt from model car. Took a month to get this far. Lots of wood n sanding. I’ll also seal the inside of the body. Cheers n happy holidays
Howard hager
Liked by Colin H and RodC
Back in the '70s i paid CAN$400 for my 1st 72MHz 4-function radio setup for a STANDARD CLASS glider, 100" span. I journalled the build, it took over 90hr. Today i get a 6-function 2.4 rig for CAN$50 from Amazon, then add $20max for a good rudder servo. Gliders dont require an ESC so the comparison ends there. My hobbies seem to get less expensive as I age.⛵
VA3ROD
Liked by Colin H
As we age Rc gets less on aircraft Boats what can happen wrong? It turns left not right but no crash
My large high speed glider went straight down liPo but like pretzel but didn’t explode or open. I blame the receiver but not so sure it wasn’t me. Boats are safer bet n less clean up on damage. Now where did I put that electric jet engine fighter?
Howard hager
Hhager2 thanks for that detailed explanation. I gave up 72MHz aircraft 7yr ago when i lost the hand-eye co-ordination & my salvation has been RC ships (which crash only in 2 dimensions, not 3). Your tech explanation warmed the cockles of my technical heart. Two point four has been a blessing to our hobby in many ways...radio apparatus is relatively inexpensive,& rechargeable batteries in the TX hav been replaced by a few AA alkalines which seem to last an entire sailing season. Additional receivers are inexpensive. The drone industry has brought us less-expensive servos & ESCs not to mention LED lighting strips. LiPOs scare me but SLAs & NiMH pks do the job well.
VA3ROD
Liked by Colin H and Ronald
Agreed n it binds much more easily too.
Howard hager
If you have a Spectrum set you have no worries, this receiver has NO Ariel to bother with.
Cheers, Pete
Liked by Colin H
Remember 2.5 ghz is attenuated by water rain too. It can penetrate buildings at times. Airplanes have height advantage n clear areas once in air. Boats can go behind vehicles or land which can attenuate signal. There is usually a fail safe mode that you program. In aircraft it’s straight ahead n motor off. Slight nose up. On boats you can set for a wide circle or motor at half? I have Rc aircraft that if signal is lost it returns to take off point n manages itself to auto pilot land. It would be good if a boat could return to launch point on auto pilot. Gps gives that ability in Rc heli n planes. It could apply to boats?
Howard hager
thanks for that ever help-full i did wonder about the metal thing i have to make a replacement mast so will make it out if plastic tube and hide it inside that I've got on order some of the castings for my 46 boat from vintage model works thanks to another member contacting them for me by the way how do you add things to ones own build blogs
Stephen james tucker
Liked by Colin H
Most 2.4ghz rx's have 2 short Antenna, one should be vertical and the other horizontal. I often drill a small hole inside a flagstaff or mast NOT METAL, or even position the receiver in the funnel.
Hope this helps, cheers Colin.
Liked by Rookysailor
2.5 ghz is diff from MHz radios The antenna is very short and can penetrate the boat easily if it’s inside it. Metal is a problem I have a spektrum radio one receiver fir gliders has a long antenna the rest are tiny couple inches. If you wanted to put a long antenna line I described inside a plastic pipe that works. Otherwise the radio with short antennas can go inside the model. Do a range check in either case to make sure. Btw 2.5 ghz won’t work under water in a sub. MHz radios can get a few feet under.
Surface craft at ghz work fine with radio just placed inside model
Howard hager
can I get away by putting the arial up in side of a mast or will the tube stop it working or how is it done
Liked by Mike Stoney and Hhager2
